Xbox 360 and 5.1 system
Discussion in 'Xbox Forums' started by paulm34, Mar 24, 2006.
  1. paulm34
    paulm34
    Feb 12, 2005
    694
    +19
    I have a panasonic 5.1 system which is connected by scart to tv. So i can use to watch tv and play dvd films with the speakers:thumbsup: . The system does not have a optical audio socket only phono sockets red/white/yellow how will my xbox 360 get DD 5.1. I will be getting a LCD TV HD ready soon if this helps the matter. I can get sound through speakers while playing xbox 360 through scart lead is this 5.1 or not please help:suicide:
  2. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,819
    Sector7
    +1,113
    Sounds like you have an older pro-logic system which was around before dolby digital came on the scene.
    To make use of the 360's true 5.1DD you will need a new sound system consisting of a digital amplifier and speakers to suit, though you may get away with using the speakers from your existing system until funds are available for a dedicated speaker system but you may have trouble with the sub woofer which usually needs to be active (internal amplification) .
    You can get a decent S/H Yamaha for around £100 and you need to be looking for Doby digital and DTS compatibility which are the basic digital sound formats and coaxial and digital optical toshlink connections, the 360 uses the latter.
    For further info you could look in the amplifier section of the forums,
    Here:-
    http://www.avforums.com/forums/forumdisplay.php?f=44
  3. paulm34
    paulm34
    Feb 12, 2005
    694
    +19
  4. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,819
    Sector7
    +1,113
    The best you will get with external equipment connected to your your system is prologic via the scart etc.. which is the best multichannel audio for analogue sound.
    To get digital audio with external sources like the 360 you need digital capable equipment with digital connections.
  5. paulm34
    paulm34
    Feb 12, 2005
    694
    +19
    ok thanks for advise:hiya: .i guess i need to update my system:thumbsdow
  6. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,819
    Sector7
    +1,113
    No probs m8!
    Your system has an amp built into the dvd player and the digital audio from DVD's etc.. are sent direct to the internal digital decoder.
    Manufacturers leave out external digital connections and have everything built in to cut costs, only later do we find this out.
    Good luck in your search, post back if you need any more help.:)
