Xbox 360 and 32PF9976/86 Philips TV
Discussion in 'Xbox Forums' started by zoidy, Mar 24, 2006.
  1. zoidy
    zoidy
    Mar 18, 2005
    693
    Surrey
    +53
    has anyone got their 360 hooked up to their 32PF9976 or 86 LCD TV? I haven't got a 360 yet, but wondered if the TV sees an output from the 360 of 1080i? I ask because I cannot for the life of me get the TV to see 1080i from my connected (DVI to DVI) PC, only 720p with the 1:1 pixel screen and borders.
    Cheers,
    Z.
  2. sekfetenmet
    sekfetenmet
    i have the 32pf9976, and was unable to get a picture from the 360 via the scart (got sound and flashing full-screen single-colour). i could hear the set-up icons beeping as i moved the control left and right, but no picture. xbox help had no clue, and advised return to shop.
    will i be able to hook up a new 360 to this tv for HD, and how?
  3. Kevinj
    Kevinj
    Apr 28, 2004
    156
    Basingstoke
    +15
    Connected to the 37pf9986 on component - no problem. Goes through the DVI/VGA / component cabel supplied with the tv. Running at 1080i no problem
  4. Amoanster
    Amoanster
    Dec 13, 2004
    174
    +6
    I managed to get the following resolutions to display on my 32pf9976:
    VGA
    1024 x 720 - has 1" border all around the screen
    1024 x 768 - has 1" border at either side of screen
    *none of the higher resolutions will display with VGA.
    Component (via a Component-DVI adapter)
    720p - has 1" border all around the screen
    1080i - full screen (Am currently using this setting)
    Hope this helps, i spent ages trying to find an answer to this question so hopefully this will clear it up once and for all.
    Aaron
