I'd be very grateful for your advice please.
I have an old XBox 360 4Gb Go and am unable to play Titan Fall on it.
The update download required is about 480MB and there was room on the internal HDD, however it always says that I require an XBox 360 HDD installed.
I have extended the memory using a 16GB USB stick formatted it to FAT32. I've tried downloading to the stick and to the internal memory, but when I try to play the game it always come up with the message that I need an XBox 360 HDD and to quit.
When searching online it says that the USB should have a section in System - Storage that says Configure - that never shows up, although the stick seems to work fine on other games.
Do I need a HDD upgrade, even though I seem to have the space required? If I do, tips on doing in cheaply and what is a good HDD would be much appreciated - I don't need loads of storage.
Thank you!
Thank you!
