Xbos surround sound with Headphones
Discussion in 'Nintendo Forums' started by smythst, Oct 20, 2004.
  1. smythst
    smythst
    OK, this may seem like a very stupid question, but is it possible to get surround sound from my Xbox through headphones. Reason being, I can;t afford a 5.1 speaker setup, but I assume I need some kind of reciever anyway to make this work.
    Anyone able to clear this up, and if so, what's a decent pair of headphones?
  2. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    By the time you've bought some surround sound speakers and a receiver/decoder you're probably not spending much less than a small 5.1 speaker/reciever system.
  3. smythst
    smythst
    Alright, but headphones really are my only option, because of neighbours/house mates. Plus I'm about to sign up for live, and will be using the headset. So have I got any options?
  4. Squiffy
    Squiffy
    May 23, 2002
    12,673
    Ashford, Kent
    +5,845
    Yes, Zalman do 5.1 headphones.
    I've got a set, and they're "OK". It isn't anywhere near the same as having a proper 5.1 setup with beefy subwoofer shaking the floor, but it IS more immersive than plain stereo.
    I got mine in the classifieds here for about £40 IIRC. I think the guy I bought them from got them from PC World originally.
  5. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Squiffy - do you use those with an Xbox?
  6. Squiffy
    Squiffy
    May 23, 2002
    12,673
    Ashford, Kent
    +5,845
    Sorry no, only used them with my PC.
    They have three connections that go into the back of my Audigy 2 in the same way as my Altec Lansing 5.1 system does.. I'm not quite sure how I'd connect them to my Xbox....
    This is a review of the same model as I've got - http://www.3dvelocity.com/reviews/zalman_hp/zalmanphones_1.htm
    I guess a search on Google for the model number (ZM-RS6F) along with Xbox might throw up some more useful stuff.
  7. Squiffy
    Squiffy
    May 23, 2002
    12,673
    Ashford, Kent
    +5,845
    Just done a quick search... :rolleyes:
    According to Zalman themselves, you need an amp.
    See http://www.zalman.co.kr/usa/product/ZM-RS6F_FAQ.htm
    It would still be worth doing your own search - some third party somewhere might have already thought of and addressed this....
  8. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Well, my research into this so far has proved less than helpful!!!
    I have found only one set of headphones with built in decoder for an optical signal - Called Mentor RCH001 - and they only seem to appear in Australia!!
    Beyond that I'm afraid it involves buying some surround sound headphones and a decoder and an amp - however I'm struggling to find a cheap stand alone decoder and/or decoder/amp.
  9. wireman
    wireman
    Jun 24, 2003
    58
    Cambridge
  10. Sting King
    Sting King
    Aug 9, 2004
    386
    Barnsley
    +6
    Ive just bought a pair of pioneer se-dir800cs for ue with my Xbox they cost £290 so not cheap,they are cordless with a built in decoder, they decode 5.1 into dolby headphone.
    They sound awesome, check out peoples reviews/opinions on this site.
    I believe they are the best surround sound headphones available at the moment.
  11. Squiffy
    Squiffy
    May 23, 2002
    12,673
    Ashford, Kent
    +5,845
    Where did you get them?
  12. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    £290!? Gulp.... You know it's serious when you spend 3x as much on the headphones as the xbox costs in the first place...!!
  13. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Seemingly available now from www.fnac.com (french site) for €150, + €8 shipping to UK that's all in about £115?!
