Quantcast
Xbmc
jammyb2004
you running LIVE? Windows?
the music stored on same machine as XBMC installed or on external NAS or usb drive?
jammyb2004
So in XBMC Go to music and add a source. The source being the folder where your music is stored. That's it!
Same as you do for videos!
jammyb2004
What you on about iTunes??? iTunes is just a player with ability to access the apple store and buy more music etc
XBMC is another player mate.
Matt_C
You don't add "iTunes" - iTunes is just a program for playing music (essentially). You have a folder full of music on your hdd (typically C: > My Documents > My Music > Music), so you add that folder as the source for XBMC for music
bryanchicken
Lol.
Where are the actual music fileson the filesystem? That's what you need to add to xbmc.
Do you understand files and folders?
Unless you are using the airtunes functionality???
As much info on what you can't achieve as possible. I'm not trying to be arsey but you've gotta help people help you :)
bagersgash
I don't really know much. All my music that I have is what I've purchased through iTunes. I don't have any music in my music folder.
bryanchicken
You can also right click the song in iTunes and find out where it is. Not sure what it's called, something like "show info" or possible "show in folder".
The songs in iTunes correspond to an actual file on the filesystem somewhere. You need to find the actual files and then add that location to xbmc.
You could try doing a search for music files. Think search is on the start menu somewher
bagersgash
Yay, I found it. Had to move it to my desktop so I could find it on xbmc. Now I can play music on xbmc. Thank you guys, I'm not very good with computers but wanting to learn. Is there any good things I can do with it now?
Matt_C
No one said to move the folder (granted, no said not to move it, but then we wrongly assumed you knew not to move it).
Move the folder back to where it was and repopulate iTunes (open iTunes, click FILE > ADD FOLDER TO LIBRARY) and choose the Music folder inside the iTunes Media Folder (which is where that folder of music should have been in the first place, and should be now after you move it back). iTunes should then populate and all be working again.
Then in XBMC, go to Music > Add Source > and navigate to that folder and add it. Done
bagersgash
I should just leave these things alone really. Thanks Matt, got it all back in there now except all my apps are gone!
Matt_C
They should still be in the iTunes Media Folder, in a folder called Mobile Applications. If they are, drag that folder into iTunes. If they aren't, then I don't know where they've gone (or why) but you can get them back by going to iTunes, clicking on Store, then over on the right clicking Purchased > then click Apps, and redownload all
Similar threads
Trending threads
Latest News
Disney developing AI based video compression
  • By Andy Bassett
  • Published
Vizio announces Disney+ available on SmartCast TVs
  • By Andy Bassett
  • Published
Audio-Technica reveals Kokutan and Asada Zakura headphones
  • By Andy Bassett
  • Published
Sky announces combined Sky Sports and BT Sport packages
  • By Andy Bassett
  • Published
Qobuz drops MP3s and introduces Studio Premier Plan
  • By Andy Bassett
  • Published
