I mean i use my XBOX as the main source to view xvid/divx/dvds/etc' and till today with both of the tv's i baught i had a very unplesent affect called ghosting/shadowing/hallowing or so with black scenes in movies/tvrips/etc'. v.soon im going to order a NEC 42" plasma (hdtv capeable ofcourse) and i want to know if there are people here with a plasma + xbox(xbmc) which tryd to run for exmple the tvshow 24(which have alot of dark/black scenes) dvd's or dvdrips and had any problam with black scenes thanks in advance, daniel.
I have viewed stuff on my plasma using XBMC and its perfectly ok . Obviously a lot of it is to do with the file you are using . For DVD's I still use my trusty , soon to be upgraded , Tosh over component John
Yep xbox media player is good especially if you have it hooked up to you nework, you can stream avi files, mp3 etc directly from your PC. Personally I dont use it that much anymore, I picked up a cheap Divx dvd player for the Tv series downloads. It plays every file I have tried and the quality is excellent. It was so good in fact I got a second one for the bedroom. You get around 12 hours of max quality divx on a dvd. Thats Over half a series of 24, lost, desperate house wives etc. Thats good enough for me. It was £42 delivered from Special Reserve. Great for the money.
