XBMC--Weather--Radio
Discussion in 'Nintendo Forums' started by geewhizz, Apr 27, 2005.
  1. geewhizz
    geewhizz
    Jan 2, 2005
    2,458
    +89
    Is there a way to change the location of the weather on xbmc, mines is stuck on london.
    Its the executer 2 chip, / slayers_evox.
    If so how can i do it, I am hooked up to the network.
    Also can i add radio stations i to it as well..
  2. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    Yes. Go to The Weather Channel site and find the code for your area using the town search (NOT the post code search as this will not give you the area code in the address bar). For instance, Belfast is UKXX0015. Then bring up the editor on any of the preset areas on XBMC weather and replace with your own code.
    Sorry, don't know anything yet about adding radio stations. I have a radio and Sky Digital for that.
  3. scary
    scary
    Jan 13, 2004
    388
    Berks
    +76
    You can change these settings in 'XBMC settings'. In the Weather tab you can search on your 'city'.
    For radion sounds like you have DNS issues. Therefore, change your XBMC settings to obtain IP address via DHCP.
  4. geewhizz
    geewhizz
    Jan 2, 2005
    2,458
    +89
    Yip Thats it.
    Sorry, I can get radio stations, I was wanting to add different ones, like radio one and so on, Is this possible ?.
