XBMC Scraper / Library Mode
Discussion in 'Xbox Forums' started by Mmarkeh, Feb 10, 2009.
  1. Mmarkeh
    Mmarkeh
    Jan 20, 2009
    65
    belfast
    Can everyone get the scrapers to work? I can't get anything to work. When I set the content of the movies folder to movies and use the IMDB scraper it seems to try but not do anything?
    Same for music and tv shows, anyone know why? Is there an easy way to see if there is actually a connection being made to IMDB so that I know its not just a network connection problem?
    help me please :D
  2. danrich1
    danrich1
    Dec 15, 2002
    389
    28
    edge of hants
    +42
    Is your networking setup correctly? Including DNS Settings?
    Do you see the RSS feed scrolling across bottom of main screen, and is weather working ok?
    Have a look at forums on xbmc.org - tons of stuff there. gl
  3. Chanser
    Chanser
    Apr 9, 2004
    1,946
    The Black Hole
    +290
    Latest build disabled some scraping. They're awaiting permission use them again.
  4. cmclean
    cmclean
    May 29, 2003
    1,011
    +117
    Where are the scrapers located?
    As I've cut one from a thread in XBMC forum and written it to a file but not sure where to now put it
  5. Wardieboy
    Wardieboy
    Nov 28, 2005
    118
    28
    +42
    E:xbmc/system/scrapers/video
