XBMC + remote control?
Discussion in 'Nintendo Forums' started by cj, Nov 15, 2004.
  1. cj
    cj
    Apr 6, 2001
    1,460
    Reading
    +74
    I have a modded XBox running XBMC and want to get a remote control (so I can program up my iPronto to use it as well). Will any of the XBox remotes work OK - they seem to be region encoded for DVD playback. There are a few for sale on FleaBay.
    Cheers,
    Colin
  2. Gary D
    Gary D
    Jan 9, 2002
    7,784
    +838
    xbox remotes are region coded.
    when you buy an xbox it has no region (in terms of DVD anyway) if you bought a region 1 remote and "eye" then it would be locked to region 1. if youbought a region 2 version - you get the idea.
    just buy the cheapest one - if its chipped then it will be multi region anyway.
    there is also an ini file that XBMC uses to set its remote control mapping.
    Gary
