XBMC question
Discussion in 'Home Entertainment Computers' started by def, Jun 4, 2008.
  1. def
    def
    Feb 21, 2004
    1,909
    63
    +142
    I realise it's not technically a HTPC, but it is a media center (and superior to the Windows ones IMO!)...
    I have an old Xbox running XBMC. I have the High definition Xbox video adapter cable thing for the Xbox - the one that gives you component video and optical audio. There's also a chunky non-standard socket on the end of it, into which I can plug a SCART adapter.
    Does anyone know if its possible to get HDMI on the original XBox using this cable? I'm already using the component inputs on my tv, so if I could use HDMI with this it would be idea.
    Thanks.
  2. anthony.s
    anthony.s
    Jan 25, 2002
    342
    28
    +62
    I doubt it.
    You could try a component to VGA adaptor such as the VDIGI Z3 to use that input if your TV has one. Component and VGA are still analogue where as DVI and HDMI are digital.
    Anything other than component out of the XBOX will also not be HD.
  3. nbaker
    nbaker
    Jun 10, 2003
    278
    Lincolnshire
    +19
    I think the only way of using HDMI on the original Xbox would be to connect the component lead to a HDMI AV receiver and then output from that using HDMI.
    This is the how I connected mine and it gives very good image quality.
  4. OctaviaN
    OctaviaN
    Nov 6, 2005
    178
    +7
  5. mossym
    mossym
    Apr 5, 2006
    12,863
    Ireland
    +2,576
  6. def
    def
    Feb 21, 2004
    1,909
    63
    +142
    Thanks. I'll go for the component to DVI option.
