XBMC Music Problem
Discussion in 'Xbox Forums' started by bigriggers, Aug 3, 2005.
  1. bigriggers
    bigriggers
    Jun 16, 2005
    354
    Birmingham
    +11
    Hi folks, having just discovered the wonders of XBMC, I'm a little upset I didn't use it a long time ago. :D
    Having a slight problem though...
    I've mapped out drives and folders on my PC so that I can see video, pictures, music etc with XBMC. I can see all the folder and files that I've shared, except for the music one. When I go into the music folder, it says something like "scanning for media information". This goes fairly quickly, but then hangs in the middle. Nothing happens when I press cancel, the only button that works is the right thumbstick, where I have to select reboot or shutdown.
    Any ideas on what is causing this?
    Thanks guys.
  2. scumball
    scumball
    Jan 12, 2004
    6,465
    Harrow - London
    +440
    Have you tried FTPing some of the music on to the XBox HD. I'm not sure what's casuing your problem as mine seems okay, but I moved all my music onto the XBox so I didn't need the LAN cable connected all the time....
