XBMC high def DVD playback problem
Discussion in 'Xbox Forums' started by clarkwgriswold, Jul 23, 2005.
  1. clarkwgriswold
    clarkwgriswold
    Jul 15, 2005
    20
    I'm having a bit of difficulty playing back dvd with XBMC in high def. I switched my modded PAL xbox to NTSC, connected it to my samsung LE32R41B LCD TV through component and selected all the 480, 720 and 1280 options. XBMC displays in 1920x1080i @ 60hz, looks great and works a treat until ... when I select 'Play DVD' from the video menu with a disc in the drive, XBMC either freezes or does nothing. The drive dispays the name of the film but I can't play any of the VOB files either. Am I doing something wrong? This happens with R1 and R2 DVDs.
    Thanks,
    andy
  2. clarkwgriswold
    clarkwgriswold
    Jul 15, 2005
    20
    Just to let you know that I've fixed it ... by using the patched version of dvdx v2. Works a treat, don't need to shell out on a progressive scan DVD player now!
  3. scumball
    scumball
    Jan 12, 2004
    6,478
    Harrow - London
    +440
    If you set this as the DVD player in XBMC do you lose the use of the remote control - and have to use the controller instead?
  4. nigelbb
    nigelbb
    Apr 4, 2005
    5,307
    103
    +491
    Yes. The upside is that compared to the XBMC DVD player it does handle menus.
  5. John DB
    John DB
    Jul 29, 2002
    344
    +7
    If you want p-scan and dvd menus and remote control then download THIS.
    And follow the instructions HERE
    HTH
    John.
