Xantech IR Kit from USA
Discussion in 'Home Cinema Control & Remote Controls' started by phurst, Sep 21, 2007.
  1. phurst
    phurst
    Jan 4, 2005
    429
    Nottingham
    +12
    I can get a Xantech IR (490-KIT) wired kit model 490-KIT (control box, IR receiver, mains supply & four 283M transmitters) from the USA when I'm over there next month for $140 which is much cheaper than the UK.
    I'm assuming that as the unit uses 12V DC then I can just dump the USA mains and use any UK 12V Dc external power supply with a 2.1mm coaxial connector.
    Hopefully someone will confirm that this is OK
    Phil
  2. AndyCob
    AndyCob
    May 3, 2005
    1,917
    +281
    Should work, or you could get the keene version, almost the same thing apart from looks and 3 wire connection I think and its less than £40 the lot from keene themselves.
