X930E or Q9FN
Discussion in 'What Is The Best TV For You?' started by Alphafighter, Aug 28, 2018.
Tags:
  1. Alphafighter
    Alphafighter
    May 23, 2017
    39
    Taiwan
    +5
    X930E is like 30% cheaper than Q9FN, which one should i get?
  2. Goldorak
    Goldorak
    Jul 30, 2011
    6,367
    Kent uk
    +5,327
    Which country you live in. Sony should be 50 percent cheaper if you find stock
    That’s the differential we have in uk...
    55: £1000 vs £2000
    65: £1300 vs £2999
  3. Alphafighter
    Alphafighter
    May 23, 2017
    39
    Taiwan
    +5
    I am from TW, price approximate in GBP
    65: 2275 vs 3200
    so which tv is preferred?
    I watched their demos on utube and there are scenes that the tvs are too bright, is it possible to change settings to fix the problem?
  4. Goldorak
    Goldorak
    Jul 30, 2011
    6,367
    Kent uk
    +5,327
    The Sony is overpriced in your country. Superb tv if it was priced like uk. Have a look at xf9 from Sony too
    Regarding advices, I suggest you go to the Samsung Q9FN thread and you will find lots of help and advices there...
    Watch also the video from hdtvtest (Vincent Teoh) about Q9fn
    If you are a gamer, Samsung always wins for the features. Some here will even ask you why you don’t consider oled.
  5. Chop_Suey
    Chop_Suey
    Feb 20, 2006
    161
    2
    46
    Isle of Man
    +105
    The Q9FN is the better TV, as it is a FALD TV, whereas the Sony is edge lit. The ZD9 (soon to be replaced by ZF9) is the closest equivalent to the Q9FN.
    Also owners seem to be unhappy with the Android operating system on Sony TV's.
