fallinlight
X570 Aorus Ultra Ryzen 3600 PC Build - No Boot, please help
Have been trying for one whole day now and this morning. New PC build, my second ever.
PC is not booting at all. No noise, beeps etc. No LEDs light up on MOBO (not sure if there should be any on first boot, I think so, manual says there are some to indicate CPU, RAM etc are working correctly). No fans spin. I have checked everything over multiple times and un-connected and re-connected everything many times, too. Only things not tried that I can think of are using a multi meter as someone suggested, to check if I am getting the correct voltage(s) from my PSU. And not tried re-seating CPU either. I tried swapping the 13A fuse inside the plug with one that definately works and I tried swapping the plug itself.
Using the 8 pin CPU power connector, as I understand from reading other forums that the 4 in one is not needed/ is optional for extreme cases of overclocking. I do not have a 4 pin lead, anyway.
Taken everything out of case to test in the open. I have some normal sounding PSU fizz when the 10 pin connector part (left one of the larger other connector) from the 24 pin power lead is connected to the PSU. When I remove this the fizz disappears, not sure if that means anything. Had a peep as best as I could at case front panel connectors (not tried disassembling case to look properly, though) and things look connected solidly/ properly.
Also tried different RAM configs: Slots 2 and 4, slot 2 alone, slot 4 alone. Do not remember trying switching them around, though.
Last I tried, I did so with everything connected, apart from the optical drive, HDD, and the rear Fractal R6 case fan as it is a bit of a stretch from the case externally. I assume I do not need any fans connected though, to get the PC booted up. Also tried removing and putting back my M.2 SSD, which is in the lowest slot at the bottom of the MOBO.
Is there anything else I can try before I return the parts? Appreciate anyone who can help, thank you kindly.
Parts:
Fractal Define R6 Blackout Mid Tower PC Gaming Case with USB-C
Gigabyte AMD Ryzen X570 AORUS PRO AM4 PCIe 4.0 ATX Motherboard
AMD Ryzen 5 3600 Gen3 6 Core AM4 CPU/Processor with Wraith Stealth Cooler
BE QUIET Dark Rock Pro 4 135 mm Silent Wings Fan CPU Cooler – Black
MSI NVIDIA GeForce GTX 1660 6GB GAMING X Turing Graphics Card
Corsair Vengeance LPX Black 16GB 3200 MHz AMD Ryzen Tuned DDR4 Memory Kit
Corsair 750 Watt RM750x Fully Modular ATX Power Supply/PSU
LG BH16NS55 Bluray Drive crossflashed with faster UHD Friendly Asus BW16D1HT FW
Samsung 970 EVO Plus 250 GB NVMe M.2 Internal SSD
Seagate Barracuda 4TB
@Sloppy Bob
Parts:
@Sloppy Bob
