X51... reckon it'll last?
Discussion in 'PC Gaming & Rigs' started by mozza54, Mar 1, 2013.
  1. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    I've been having a look for a new pc setup and I've found a decent deal on the i5 version of the alienware x51. My only concern is in not sure if it would last???
    Spending that much on a system I want be able to get at least 2 years off the back of it but I don't know if it would... Oppinions anyone?
    (I know I could put together a system for the same price with a little more power but the form factor of the alienware is better for me)
  2. GMC79
    GMC79
    Apr 1, 2006
    10,641
    Glasgow
    +3,177
    It would last yes, but overall could do much better for that money on a self build, Or prob do much better from an overclockers build.
    Example below.
    cracking buy imo if dont want to build one, I bought from there and couldnt fault them, packaging had what seemed like 30m of bubble wrap in monster box. Have since built mate a rig and is easy really.
    "Vortex i7" Intel Core i7 3770 3.40GHz DDR3 Quad Core Gaming PC [FS-309-OE]
  3. Jamezinho
    Jamezinho
    Apr 12, 2007
    10,646
    Ipswich, Suffolk
    +3,353
    Sebastalona recently built a small form factor PC that makes the X51 look over-priced and under-powered. Which it is.
    If money is no object go for it but you can do better with a self build.
  4. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    Ill have to keep looking, I wanted the x51 purely because of the size and the reviews. I have usually gone self build but couldt find what I wanted for cheaper.
    The deal for the alienware is 714 for the i5
  5. bladedripper
    bladedripper
    Nov 26, 2007
    5,071
    Birmingham
    +1,527
    It will last 2 years for minesweep...:smashin:
  6. mozza54
    mozza54
    Aug 25, 2010
    3,298
    Rotherham
    +432
    This is true I guess lol. I've googling around all day and its actually not that bad a deal. I spec'd up a machine myself with an it type setup and could save £100 if I use one of the HDS I already have.. As you've said, the upshot of doing it myself is as slightly better spec
