x4000 upgrade to? anthem MRX 710/Marantz AV7701 MM8077
Discussion in 'AV Receivers & Amplifiers' started by robhart84, Feb 12, 2014.
Tags:
  1. robhart84
    robhart84
    May 31, 2007
    110
    19
    Epsom
    Hey All
    So I've been thinking about upgrading my Denon X4000 as I wanted to get the most out of my Monitor GX speaker system. I was originally looking at the AV8801 but that with the MM8077 is nearly 3k and although I could afford it I don't think I can justify spending that amount of money. So now I'm looking at the AV7701 with the MM8077 and also seen the anthem MRX 710. Basically I need some help as to whether upgrading will be worth it on a 2k budget and what you can recommend if it is worth it. Usage is about 70% movies 30% music.
    Thanks in advance
  2. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    Mrx510 with a mca30 will give you stunning performance. If 5.1 or 7.1 is all you are ever going to need then the anthem will do the job for you
  3. lokyc
    lokyc
    Aug 28, 2013
    2,176
    83
    +429
    Can i be controversial and suggest you add a power amp instead. It will improve your soundstage nand make it more "forward". An ATI 1805 is less than 2k. Throw in a KKDXD808 sub and you're just over 3k
