X2VGA or Component
Discussion in 'Xbox Forums' started by WoodyC, Jul 7, 2005.
  1. WoodyC
    WoodyC
    Feb 7, 2005
    47
    9
    Slight dilemma that I hope someone will be able to help me with. I've currently got my DVD player plugged in via component. I'm going to do the soft mod to enable high def on my Xbox (hopefully) and was going to get an X2vga so that I can run it in via the VGA port. The problem is that I've heard some games won't run in (at least) 480P and so I won't get a usable display. I don't want to have to switch cables around all the time so I'm now thinking of getting a component switcher and have them both plugged in at the same. Does anyone know if I'll have any issues with games that don't support prog scan?
  2. Trousers
    Trousers
    Jun 16, 2005
    93
    I got the component switcher from tmfsolutions (www.tmfsolutions.co.uk) via these forums and it works a treat with the Xbox and DVD player. I've soft modded like yourself and so far every single game I have tried runs fine and looks superb on my PV500.
    I understand the GTA games may prove troublesome though.
  3. WoodyC
    WoodyC
    Feb 7, 2005
    47
    9
    Thanks for the reply. Does the MS dash display properly via component? I know it doesn't through the X2VGA. It's just the handling of a 480i signal that I'm thinking about.
  4. Trousers
    Trousers
    Jun 16, 2005
    93
    Aye it displays fine but you can stick it into 480p by clicking both thumbsticks and triggers down at the same time.
  5. WoodyC
    WoodyC
    Feb 7, 2005
    47
    9
    Thanks for that. Looks like component switcher is the way forward. :thumbsup:
  6. fathervic
    fathervic
    Jul 6, 2005
    285
    Scotland
    +18
    I want to get the best video out from my Xbox but I also run LIVE. Getting my box modded, I've heard can, cause a problem as they're very strict on policy and if the system finds that you're running a modded box, they'll ban you from LIVE...
    Is the mod just for the video card to run PAL games in pseudo PAL progressive like DVDs, or is it chipped to play import games?
    Also, would the standard component lead suffice or is there a special one you'd need to buy?
  7. Trousers
    Trousers
    Jun 16, 2005
    93
  8. fathervic
    fathervic
    Jul 6, 2005
    285
    Scotland
    +18
    thanks...
    I can now look forward to my plamsa upgrade :smashin:
  9. jackylad
    jackylad
    Jul 20, 2004
    161
    16
  10. neil c
    neil c
    Mar 25, 2005
    537
    +3
    I've done the soft-mod, and I was on Live before the mod and I'm still on Live after the mod, no bannings here!
  11. scumball
    scumball
    Jan 12, 2004
    6,465
    Harrow - London
    +440
    That's DVI to Component, I'm guessing you want the other way round - and I don't think it'll work anyway it states it can only be used with certain Graphics cards and also This adapter is ONLY COMPATIBLE with ATI products
  12. jackylad
    jackylad
    Jul 20, 2004
    161
    16
    Thanks Scumball
    So what would you guys do if you wanted to connect your xobx to an lcd with every connection possible apart from component in (my Scarts are RGB though) In an ideal world the VGA of DVI connections is what I want to use. But as I'm new to the xbox I've got no idea what you can buy in regard to cable options.
    I've tried searching but can only find s-vid and component is that the best you can get?
  13. scumball
    scumball
    Jan 12, 2004
    6,465
    Harrow - London
    +440
    you could get a vga to dvi-a adaptor and use x2vga - will your TV accept dvi-a or just dvi-d? If digital only you may be out of luck...
