In comparison to the human eye this will be about 8x magnification.
The standard (i.e. where a lens presents a subject in the same way that is percieved by the human eye in terms of perspective) is usually taken at 50mm.
Most camcorders with built in lenses (i.e. not professional with interchangable lenses) have a wide angle of around 40mm, so it is slightly wider than we would percieve an object, therefore a 10x zoom has roughly the effect of 8x the human perspective.
Unless you are using a tripod, beyond 10x zoom is pretty unworkable.
There is also more to it in terms of how lenses flatten (telephoto) or stretch (wide) a subject and how the depth of focus decreases as a lens focal length increases (independantly of aperture).
Bigger isn't always better, domestic camcorders with more than 10x usually suffer from chromatic abberation ('fringing', coloured halos around the subject) and even with a zoom range of 10 there will be pincushion distortion and barrell distorion at opposite ends of the zoom.
The other advice is to avoid digital zooms at all costs.
