x10 sutter switch problem
Discussion in 'Home Cinema Control & Remote Controls' started by aarons, Aug 13, 2003.
  1. aarons
    aarons
    i have just obtained one of these switches is there anyone who knows how to reset them as it has been set for the previous owners screen.help would be appreciated.thanks
  2. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    I haven't got the manual with me but I think you just turn the address dial to the asterix and then use the switch to move the screen into the correct position. The switch will time this and memorise it. You then change it to the address you want to use.
    You may have to do it quite a few times to get it just right.
    Cheers,
    Cal.
