X10 Module Repairs
milanlad
Does anyone know where I can get some X10 modules repaired?
I have a few appliance and lamp (AM12 and LM12) modules that have stopped fuctioning?
Are there any circuit diagrams available out there for these modules?
Many thanks in advance.
smjxm09
Is the controller battery operated? Have you changed the battery?
stoobie
Have you actually had them working? Did they all stop at the same time? How are you controling them? (what remote control?).
It is very unlikely they all stopped working unless there was some sort of power surge or something like that.
Stoobie
milanlad
Stoobie
They have all worked before. They stopped functioning at different times.
However, last week, our power went off due to a network fault, but when it came back on it cycled the power two or three times within 1 second. The result of this was that another TM13 RF module and a power supply from my printer buffer blew.
davehk
It'll almost certainly be cheaper to buy new ones, labour rates being what they are.
milanlad
I was hoping to find a circuit diagram or info on which parts (triacs etc ) are used in these modules - I'm quite handy with a soldering iron and basic fault finding.
davehk
Quite often it's the VDR that pops when you get a power surge, but it generally takes a few other components with it and damages the PCB.
Is there any smell of burning? If so, this is probably what has happened in which case I would not try a repair, even if you can find the component values (I've tried to get schematics before with no luck).
