x10 light switches
Discussion in 'Home Cinema Buying & Building' started by howies, Nov 27, 2003.
  1. howies
    howies
    i want some x10 light switches that look nice not those blocky white things. but that is all i can seem to find , does anybody know of any that look good.
  2. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    I remembered seeing the X10 light swiches (UK version) a while back, and wasn't keen on the looks.
    Anyway, after extending my X10 system recently, I decided to order them and was pleasantly surprised. They're not as bad looking in real life (ie on the wall) as they seem from the pics on the net.
    The reason for their bulk is because of the 'electronics' they need to contain, whilst having to remain fairly shallow round the back (the UK uses shallow back boxes for light switches).
    Lights in the UK don't normally have a neutral wire available at the switch (unlike other countries), and so these switches were specially designed for us brits and only require the live connection.
  3. JediJackass
    JediJackass
  4. jsmurray
    jsmurray
    I have an LW10U standard dimmer from letsautomate, but I cannot control it with my ir7243. Any ideas?
    It doesn't respond to any commands.
    FYI, it IS set to the same housecode and a unique device number.
    Could it be due to my fuse box? This is a new house, so the sockets and lighting uses different circuits AFAIK.
  5. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    It shouldn't matter about lighting and sockets being on different circuits (mine are), it should still work.
    Do you have any other means of controlling the switch (ie RF remote), to check its not the IR7243 at fault?
    I had a bit of a problem with my IR7243 at first - its worth trying out different posistions and different sockets for it to be plugged into.
  6. Doublespresso
    Doublespresso
    Dec 8, 2003
    59
    9
    London
  7. alan8477
    alan8477
    Dec 17, 2001
    593
    Pershore
    +11
    They are very good value, but mine packed up after 3 months.
  8. jsmurray
    jsmurray
    Well I took my LW10U dimmer off the wall and cabled it up to a mains socket with a light bulb connected. The X10 controls work fine this way. The problem must be the RCD circuit.
    All the mains is RCD protected, but the lighting is not.
    Looks like I can't have X10 lights after all.
  9. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    My house is the same - mains circuits are RCD protected/Lights not. But no Problems.
    May be worth trying another LW10.
    NB You didn't have the LW10 screwed to the wall too tight? - as this can jam the microswitches inside the unit.
  10. Andrew_arkless
    Andrew_arkless
    Sep 19, 2001
    181
    Essex
    +6
    I agree with alan8477 about the switches from TLC-direct, I'm onto my 3rd set of these as they die very quick! so would not recommend them. Alan - did you get them replaced ? the manufactures have always replaced mine no problem, i've got their details if you need them.
  11. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    What about when you needs a two gang light switch, in a single standard package, in the X-10 type? I have not seen any that come in this format..
    Any thoughts?
  12. ailean
    ailean
    I've gone for the TLC type one because basicly it's the only two gang dimmer I can find. At least they do fix stuff under warrenty. ;)
    After much searching I did spot some X10 multi-gang dimmers but they were an american company that didn't appear to do any 240v stuff. :(
  13. alan8477
    alan8477
    Dec 17, 2001
    593
    Pershore
    +11
    Unfortunately Andrew, I couldn't find my receipt.
