X1 Projector/VGA
Discussion in 'Projectors, Screens & Video Processors' started by melphillips, Jan 27, 2004.
  1. melphillips
    melphillips
    I have an X1 projector and currently am feeding it with composite only (Agh!). I want to run a 25' VGA cable from my PC for viewing video from the PC. I have a Pace HDTV box coming from the cable company so i can set the unit up to view from the component signal from my stereo.
    A couple questions?
    1. Can anyone give me a good source and recommend sizing a VGA cable for the 25' run that will not have quality degradation. I understand that i should be able to view at 1080i which should really be crisp.
    2. Is the component video out signal on the HDTV cable boxes a progressive signal? The X1 only takes in component if it is progressive.
    3. Also, can anyone recommend a digital audio cable for a 30' run. I have digital audio on my PC which i would need to run into my stereo.
    Thanks in advance for any help given.
    Mel Phillips
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,085
    UK.
    +2,578
    Hi Mel,
    I bought a 25ft vga to vga cable from here:
    http://www.itm-components.com/
    They do cables that guarentee no degredation up to 200ft IIRC.
    And Lindy's do good cables too:
    http://www.lindy.com/uk/
    I can't help you with the HDTV stuff - are you in the USA? If so, Lindy have a US outlet, so try that one instead.
    Gary.
  3. Paul Williams
    Paul Williams
    Jul 4, 2003
    812
    Plymouth/Devon
    +16
    Hi Mel,
    The X1 can take component input (interlaced) through the modified svideo socket, but not at 1080i, for that you will need an output to the VGA port. A good quality cable would be those manufactured from Belden stock, if you are in the US(?) try the links below. For digital and video feeds 25/30 foot is not overly long, so should pose no problem as long as the cables are reasonable and well screened.
    http://www.ramelectronics.net/
    http://www.bluejeanscable.com/
    Paul
  4. melphillips
    melphillips
    Paul, Can i run component out from my stereo system into the VGA port of the X1 and get the 1080i. If this would work, then i could go from VGA to component on my pc and feed the stereo as well as feed component in from HDTV and the DVD player into the sterep. then a single component to VGA cable into the X1, which i already have the cable for. If this would work, that would be great. Thanks for the help.
    Mel
