X1 Controller Range ?Extender
Discussion in 'Xbox One Accessories' started by 28061, Jul 9, 2015.
  1. 28061
    28061
    May 29, 2015
    862
    46
    Staffordshire, UK
    +243
    We're moving to a new house in a few months and I'm intending to move all my kit into an upstairs rack but am worried the X1 controller won't hack the range.
    Any experience?
    I take it there's still no range extenders?
    I'm not averse to using cabled controllers... I'm running Cat6 & coax anyway and can run powered usb if I have to...
  2. pembssurfer
    pembssurfer
    Sep 23, 2006
    1,477
    63
    +246
    Not sure of exact range but it's Awful. I have a kitchen 5m away from X1 setup it's open with only plasterboard wAlls and it won't work in there. The 360 one worked everywhere including my back yard. Go figure.
  3. 28061
    28061
    May 29, 2015
    862
    46
    Staffordshire, UK
    +243
  4. kerbys
    kerbys
    Dec 22, 2010
    1,479
    48
    +86
    im tempted to try it but was worried over the usb 1.1. was thinking extender to 4 port powered usb hub then cables to controllers.
    The other longer option is get the windows xbox one controller adapter, and use a nuc or something simular to stream from xbox?
    ** edit sorry just seen thats an active cable i was looking at the usb over cat 5/6
  5. Martin.D
    Martin.D
    Jul 12, 2007
    1,351
    Germany - PB
    +284
    I have my Xbox One 7 meters away from where I play - I too was worried about the range so I installed USB Extenders over CAT 5...
    I installed an extra power socket for the 5v power supply to feed extra power to the USB extender...
    Works and treat!
  6. kerbys
    kerbys
    Dec 22, 2010
    1,479
    48
    +86
    which ones did you use?
  7. Martin.D
    Martin.D
    Jul 12, 2007
    1,351
    Germany - PB
    +284
    In all honesty I can not remember - just purchased a set of top rated extenders from Amazon and a 5v power supply to go with it..
    See link below:
    USB Extender
  8. 28061
    28061
    May 29, 2015
    862
    46
    Staffordshire, UK
    +243
    That's dead useful thank you :)
