Quantcast
x-trail tyres
ssttaagg
i have a 2004 nissan x-trail and the n/s front tyre inner shoulder keeps wearing down. i have had the tracking done and re-checked and it is all fine.help:lease:
paulyoung666
Do you mean the same tyre keeps wearing or a new tyre , if the former , then it will ...
ssttaagg
it is in the same place evey time i put a new one on
DVD-Man
Then you want to get a 4 wheel alignment check done. Think the machine used is called Hunter.
ssttaagg
it is only on the n/s inner shoulder all the others are fine.
i will get it booked in next week and have it checked.
Similar threads
