X-fi optical out to 5.1 receiver - DTS?
Discussion in 'Computer Components' started by sickbird, Sep 14, 2007.
  1. sickbird
    sickbird
    Aug 31, 2007
    84
    Has anyone managed to get an x-fi to output true 5.1 Dolby Digital/DTS to a receiver? I get sound from all of my speakers but, when watching a suitably encoded DVD (via MCE2005), my receiver is not showing the signal being received as being Dolby Digital or DTS (as it does when watching BBC HD on my V+).
    My set up is:
    My PC has an x-fi xtrememusic soundcard, connected to which is the creative digital I/O module (which plugs into the flexijack). This is connected by optical cable to my receiver which is a cambridge azur 540R.
    I have installed AC3 filter but am not sure whether it is actually being used - when I go through the mce speaker set up (to tell mce I've got 5.1 speakers attached) I do not hear the test tones from the rear speakers (but the fronts and sub are fine). To troubleshoot this, MCE then tells me to configure my DVD audio settings and it automatically brings up an nvidia window (as opposed to AC3) where I tell it that I've got the PC hooked up to a receiver. I run the speaker set up again and still get no test tone from the rears. I have nvidia purevideo decoder installed.
    When I go into the creative x-fi program within mce it will not let me select the DTS or DPL II options.
    When I go into AC3 filter and make changes they do not seem to have any effect.
    I've tried all the different sound modes on my receiver (inculding passthru) but, despite getting sound from all speakers whilst watching a DVD, the DTS/Dolby Digital light does not come on the receiver (which suggests to me that the DTS signal is not making its way to the receiver). The limited surround sound I do get is presumably emulated (DPL?) by the x-fi. Am I going crazy - should the light not come on at all?
    I've read about people having trouble with getting full AC3 5.1 from avis but never from DVDs on mce.
    This is so annoying - short of buying a separate DVD player and hooking that up directly to the receiver I don't know how else to get proper 5.1 from DVDs, but I really want to use mce as my DVD player.
    Any ideas? :lease:
  2. dogbert
    dogbert
    Feb 6, 2005
    207
    28
    +24
    I hear sem1604 is selling a Trust SC5200 card which "just works" with my drivers 8).
  3. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,008
    +265
    I don't think the Creative X-Fi drivers / software currently support Dolby Digital / DTS although that may just be for Vista...
    I'm sure I read that somewhere but I can't remember where. Have a quick search on Google... You might find the reason.
  4. sickbird
    sickbird
    Aug 31, 2007
    84
    I know the x-fi does support DTS, but presumably that it only through analogue? It seems strange that creative would cripple the optical output in this way?
    Now I feel stupid for buying the digital I/O module...:mad:
  5. chrisbaker42
    chrisbaker42
    Apr 8, 2005
    1,645
    48
    Near Lampeter
    +96
    If you place the pointer over the speaker symbol on the toolbar does it show that you are using spdif output?
  6. sickbird
    sickbird
    Aug 31, 2007
    84
    I'll try it when I get home but I am definitely using SPDIF as I get sound through all of the speakers, just not in DTS. I have no analogue connections plugged in.
  7. sickbird
    sickbird
    Aug 31, 2007
    84
    UPDATE: I have got DTS working, but only by using PowerDVD - still will not work through mce.
  8. Bagger
    Bagger
    May 8, 2007
    2,225
    Leicester
    +227
  9. Trancerii
    Trancerii
    Jan 10, 2004
    360
    28
    +47
    Try following through this: http://www.projecthtpc.co.uk/troubleshooting.html
    If you can get it working through graphedit, it should work in MCE.
  10. apple1in
    apple1in
    Apr 7, 2009
    11
    kings lynn
    +6
    I to have had problems with spdif dts works ok with driver ( vista) that came with card but when i update the driver with the latest using auto updating program can not get DD or DTS only through neo 6 when i try to set it to spdif it tells me that it is being used by another application any ideas
