x box wont start
Discussion in 'Nintendo Forums' started by micks_address, Sep 1, 2004.
  1. micks_address
    micks_address
    Nov 29, 2001
    4,635
    83
    Dublin
    +234
    hi folks -
    when i tried to switch on my x box the other night is sort of tried reading the disc - then the green light around the button on the front flashed red and the machine shut itself down again - i didnt have much of a chance to play around with it but has anyone seen this type of behaviour before and is it bad news?
    Cheers,
    Mick
    p.s the box is modded with an executor 2 chip i think... (only bought it a couple of months ago from these forums)
  2. John
    John
    Dec 13, 2002
    11,303
    +2,922
    I think when it flashes red , its a dvd drive failure , could be something else tho ,
  3. spidermanalf
    spidermanalf
    Oct 25, 2002
    2,000
    63
    Wakefield
    +103
    If you have a spare dvd drive, then unplug your dvd out the back of teh xbox, and put the drive in, and see if that works, I had the same problem, and did that!
    It may not be pretty but it works, and was only 25 quid to repair!
  4. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Do you get a message on the screen with a number in the corner? It's most likely the chip has come loose in some way. Probably the d0 wire needs re-fixing. Difficult to tell without looking at it.
  5. micks_address
    micks_address
    Nov 29, 2001
    4,635
    83
    Dublin
    +234
    will check it out this evening to see if there's a message - whats the d0 wire?
  6. Pooon
    Pooon
    Dec 26, 2002
    7,366
    Canterbury, Kent
    +957
    Might sound stupid, but if the A/V cable isn't pushed in all the way the lights on the front of the xbox flashes, but i can't remember if its red though. But it could be that!
  7. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    It's a wire that's soldered directly to the board during chipping but it's the most fiddly bit and the most likely bit to come loose if the chipper was not a competant solderist.
    Also, could be a pin header install and the chip itself needs a wiggle. Or could be a failed hard drive or any number of loose cables. Basically it probably all needs checking and putting back together properly. A 10 minute job for somebody who knows what's what.
