X-box version?
Discussion in 'Nintendo Forums' started by Kramer, Nov 20, 2003.
  1. Kramer
    Kramer
    OK, just wondering which version x-box I've just received (needed for a "chip ;)).
    It's something like K:1.00.####.01
    D:1.00.####.03 in system info.
    Version 1.5?
    Cheers.
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Not sure what chip you need but make sure you get a switch put on the the mod so you can switch it off for live.
  3. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    You just need to check the serial number on the bottom label.
    Serial Number v1.0 : XXXXXXX 20XXX (20, 21 = v1.0)
    Serial Number v1.1 : XXXXXXX 24XXX (24, 25 = v1.1)
    Serial Number v1.2 : XXXXXXX 30XXX (30 = v1.2)
    Serial Number v1.3 : XXXXXXX 31XXX (31 = v1.3 )
    Serial Number v1.4 : XXXXXXX 33XXX (33 = v1.4 )
    Serial Number v1.5 : XXXXXXX 34XXX (34 = v1.5 ?? )
    [EDIT] the last 3 digits (now replaced by XXX above) were only intended as examples. It is the first 2 digits of the second batch of 5 digits that are the tell tale ones.
  4. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    added to the faq.
  5. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    Those numberes aren't quite right - I have a 30905 v1.2 (or v1.3 - i'm still not sure which)
    Here's a great resource for working out xbox versions:
    http://xbox-linux.sourceforge.net/docs/versionsfinding.html
    btw "30205" is just the date is was manufactured, and the factory code. i.e:
    03/02/05 = year 2003, week "02", factory "05" (which is china).
  6. Kramer
    Kramer
    XXXXXXXX34105
    Version 1.5 then I guess :)
    Made 11/10/03 :clap:
    Cheers guys.
  7. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    bump. the faq needs to be updated with this info.
