x box @ toys r us
Discussion in 'Shopping, Deals, Discounts & Bargains' started by spocktra, Mar 16, 2006.
  1. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    x box with 5 games £99.99 at toys r us.
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,993
    London
    +1,149
    Which games are these?
  3. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Can`t remember,saw it on a flyer.
  4. stephanbegley
    stephanbegley
    Dec 5, 2005
    212
    Belfast
    +11
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,993
    London
    +1,149
    I've seen this recently, Halo 2 seems to be the best of the bunch. If you're not going to play the other games then it's probably worth just buying the console from play.com for £80 and buy games you do want to play from there.
  6. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    I am thinking of getting the £80 console from play.As i am fairly new this gaming lark i was wondering what are the modifications i have been reading regards x box media center etc.
  7. Chanser
    Chanser
    Apr 9, 2004
    1,946
    The Black Hole
    +290
    There's the £88 Xbox bundle which contains Burnout Revenge, from Komplett.
    Check out Xbox-scene.org about the modifications, there's the soft and hard mod way.
  8. Tejstar
    Tejstar
    Dec 4, 2002
    22,993
    London
    +1,149
    If you are looking at using Xbox Media Center then I'd recommend a hard mod, there's plenty of good sites out there but your first port of call should be Xbox Scene.
  9. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Thanks for the advice,probably order one next week.
