X Box set up advice.
welshpaul
Have just bought the advanced scart lead.
Will run the digital lead directly to the amp but my TV has only one RGB scart which is currently being used by Sky +.
I intend running the box via the Sky + as it has RGB in but was wondering how this works in practice.
Would turning the box on overide the Sky + or would i have to turn Sky + off to use?
John
This is exactly as mine was set up before I moved house , XBOX - SKY - TV , Turn XBOX on , it took priority from sky .Never had any problems with quality
harrisuk
Its got RGB pass through so you should not see any real difference in quality. It wont effect your sky box at all and works whether it is on or off. Its a hardwired connection I believe.
Samsung S95B QD OLED Review - A Quantum Leap for OLED!
