x box - s video and 5.1 ?
Discussion in 'Nintendo Forums' started by common, Apr 19, 2002.
  1. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    Can I get 5.1 using an s video connection + a seperate optical lead from the Xbox ? I seem to remember you can only get 5.1 by using the advanced scart.
  2. paiger
    paiger
    You can get an AV pack that has an Svideo out and also an optical out. I think it's called the Advanced AV Pack but I'm not sure. Not sure where you would get it from either but I've definately seen one.
    S
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Joytech
    £15 Dixons
  4. john87
    john87
    On a seperate note, does the XBox have a coaxial output.
  5. ashearer
    ashearer
    Feb 14, 2002
    244
    Binfield, Berkshire
    Firstly, you cannot get Coaxial out for the XBOX although I believe you can buy optical to coax convertors (try Maplins).
    Secondly, you can get an S-Video version of the official Advanced AV Pack which has optical out plus S-Video out. I am not sure if you can get them in the shops here yet. I got mine from www.lik-sang.com
