x box rgb
Discussion in 'Nintendo Forums' started by gagde, Jun 26, 2004.
  1. gagde
    gagde
    Jun 12, 2004
    152
    +3
    dont know if this is the right place so here go just got a cable set for x box optical rgb and so on now i have got my xbox in 5.1 sound but now when its set to rgb the pictures green but when i turn off rgb on my scart box its okay again how can i get rid of the green the set i brought is a joytech digital av cable everything else is great but the picture.
    thanks garry ;)
  2. andy572
    andy572
    Dec 4, 2002
    362
    Oop North
    First, the obvious route is to check the connections. Reseat the cables and you may find that all is well :)
    Failing that, if you have something like the £10 switcher sold at Argos, press the 'recode' buttons half way (er, if they exist!), until they 'unclick'. With a little luck, you'll be green-free and can duly run around the room, screaming 'Yay', 'Woo', 'Weeeeee' and 'Woohoo!'. Go on, give it a go...
    I've been caught out a couple of times with each of these issues, so here's hoping that they'll be the fix for you :smashin:
