Quantcast
x box headset
AidyTy
Hi there
My son's headset wasnt working so while in HMV today the missus and I impulsively bought a headset that said suitable for online gaming but when I opened it and looked at it - it had two connections with bigger plugs that what would fit the xbox 360 controller.
Can you buy an adaptor for this or have I just wasted money?
cheers
AidyTy
AidyTy
thanks DJSigma....unfortunately I opened it before I knew that it had two plugs so can't return it!!!!
I will get one of those adapters, thanks again.
DJSigma
No problem! You could try giving your local HMV a bell and see what their returns policy is, as opening the box doesn't necessarily stop you from returning an item, but yeah - otherwise, that adapter will do the trick. :)
Similar threads
