X-box for DVD palyback?
Discussion in 'Projectors, Screens & Video Processors' started by malcolm, Jun 26, 2003.
  1. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    +3
    Hi guys,
    Does anyone use there x-box for playing DVD's ?
    I may use the X-box to save on buying a new DVD for the projector (when i decide what to buy).
    Would anyone advise against this?
  2. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    I'm not sure this will help but I use a chipped UK Xbox running DVDx2 software with progressive scan patch in NTSC vid mode thru component video cables into my Panny AE100 and the image is stunning. It's really hard to tell the difference between this set up and using my HCPC.
  3. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    +3
    yes, thats certainly an option > to get it chipped!
    Did you try it before it was chipped?
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    The Xbox uses the same video decoding codecs as PowerDVD, if I remmember correctly.
  5. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    I would strongly recommend you don't rely on your X-box for playing DVDs as the PQ is poor - lots of pixellation/blocking, poor contrast level, and that's vs my old 'budget' Tosh SD100E.
    It's a stonking console but can't cut the mustard with DVDs, get yourself a Tosh 330 instead if DVD playback matters but funds are limited.
  6. donmc
    donmc
    Can you tell us any more about this ?
    Don
    Another UK Chipped XBox user :clap:
  7. MaxCPU
    MaxCPU
    I totally agree! It's better than PS2 but it's a long step back from my harman/kardon dvd-25! DVD players better than the Xbox are cheap... :smashin:
  8. gingercat
    gingercat
    Nov 19, 2002
    489
    Lancashire, UK
    +26
    I've used my XBox for this in progressive mode, but it really isn't worth it - the player software doesn't make a very good job of the de-interlacing and leaves you with a rather nasty looking image imho. Now if someone could release a homebrew DVD player for the XBox with proper 2:2 and 3:2 pulldown, then I'd be happy :)
  9. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    +3
    cheers for the feedback guys.
    I'll certainly knock that idea on the head!
    deckard recormended the toshiba 330 as a cheap DVD player alternative, cheers for that..:)
    Any other suggestions while we're on the subject!
  10. cyberheater
    cyberheater
    Apr 3, 2003
    3,190
    Scotland
    +175
    Hold your horses there Malcolm. If you have a chipped Xbox, you should seriously check out the DVD-x2 software DVD player for it and get the progressive scan patch for it. Switch your vid mode on your Xbox to ntsc using the vid mode select app and then use component video cables to your Panny. You won't be dissappointed with the picture. It looks awesome.
    Edit: I just bought the Compacks 5000 dvd player with progressive scan output on Pal and my Xbox looks a hell of a lot better. Better colours, much higher resolution.
    Don't think I'll be looking around for a new DVD player for a while now.
  11. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    +3
    Cheers for that Cyberheater.
    I must admit i like my x-box pure, as nature intened! :p
    I think i'll look further into getting a new Player.
