X-Box DVD Region Unlock Code?
Discussion in 'Xbox Forums' started by BIGINOIL, Jul 17, 2005.
  1. BIGINOIL
    BIGINOIL
    I've had a good look through the forum and can't see it, apologies if this is one of your top-10 newbie questions!
    Is there a DVD region unlock code for the X-Box?
  2. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,161
    68
    +69
    No.
  3. BIGINOIL
    BIGINOIL
  4. scumball
    scumball
    Jan 12, 2004
    6,478
    Harrow - London
    +440
    I got a CD iso from a download that ran a small Linux program that makes the XBox drive region free and put's it back again if you want. This is so I could still use the remote control with it as the hacked DVD player (for use on modded boxes) only uses the controller.
    For a limited time only - available here
  5. BIGINOIL
    BIGINOIL
    Thanks Scumball - you're a star!
    I've got an American DVD that I've never seen, a Panasonic DVD player (which can't be unlocked) and an unchipped X-Box. If this works, I'll be made up! I'll be sure to let you know!
    Thanks again!
  6. scumball
    scumball
    Jan 12, 2004
    6,478
    Harrow - London
    +440
    Thinking about it you may need a chipped or softmodded Xbox to run this as I'm guessing it will be unsigned code.... :(
    You may have to get a Region 1 DVD dongle from the US - may be worth trying eBay...
  7. mcgetta
    mcgetta
    Apr 12, 2005
    30
    Can the Slayer Auto ionstaller be used in conjunction with the Splinter cell soft mod. The reason I ask is that i can manipulate the soft mod to the point whereby the Xbox is accessed via ftp. I can view all the available drives but what then. What files do I need and where to put them on the xbox C: partition in order to enable hi def and play my backups.
    Will Slayer enable all this?
  8. scumball
    scumball
    Jan 12, 2004
    6,478
    Harrow - London
    +440
    Why don't you try and install Evo-X (if you have it) as the new dashboard. If it's setup properly in the Evox.ini file then all your programs should be accessible from there.
    You need enigmah video switch to change to NTSC. Once changed you then access the HD options from the MS dashboard - under video options.
  9. BIGINOIL
    BIGINOIL
    Can't say I understand all your advice right at the moment, but I will certainly investigate further. I have a mate at work who might know about the Evo-X thing - he's a bit more into this than me. Certainly interested in unlocking more of the capabilities of the X-Box. Many thanks!
  10. -Hitman-
    -Hitman-
    Mar 21, 2005
    4,807
    Sector7
    +1,112
    Most ppl are using DvdX 2.0 which is also multiregion and you will need a modded box!
    DvdX is also included with slayers installer (slayers installer now at version 2.6).
    Dr.
  11. scumball
    scumball
    Jan 12, 2004
    6,478
    Harrow - London
    +440
    My problem was that you cannot use the XBox remote with DVDx only the controllers....
  12. scumball
    scumball
    Jan 12, 2004
    6,478
    Harrow - London
    +440
    The Evo-X advice was for mcgetta...
