X-box connections - confused!
Discussion in 'Nintendo Forums' started by daveb975, Sep 13, 2004.
  1. daveb975
    daveb975
    Oct 25, 2002
    4,360
    103
    London
    +371
    First of all, I apologise is this question has been answered before. I have searched the forum, and found a lot of information, but am still a little confused.
    I want to connect my standard PAL XBox to my Panasonic PWD6 plasma. The only free connector that I have is the PC input.
    I have a lead that has the PC connector on one end, and component connectors on the other (I used to use this for DVD input) . I was thinking that if I get the MS Hi-Def pack for the Xbox, I can use this lead to connect to the plasma, thus eliminating the need for switch boxes on my other inputs.
    My questions are as follows:
    1. Is the above correct?
    2. As I will not be able to output progressive on a standard UK Xbox, will this set up give me any better picture quality than using an MS Advanced SCART lead, and a switch box?
    Thanks in advance for any suggestions!
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    get the MADCOW box, I paid £12.99 for mine delivered it has
    video outs
    component, SCART, s-video, composite
    Audio outs
    Phono, digital co-ax, digital optical (TOSlink)
    what more could you ask for?
    PS
    UK unchipped xbox cannot do progressive output
    UK chipped xbox + Enigmah Video switcher (switch to NTSC) can
    RBG SCART is as good as you can get without progressive
    (RGB SCART has higher quality signal than interlaced component)
  3. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    sounds cheap mr clark, tell me does it output to all at once?
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  5. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    the reason I ask is because interlaced component has a horrible banding effect on my LCD, I know us ask why interlaced?
    well certain live games Like PAL Indycar racing 2k5 wont run in NTSC mode, so I have to revert my xbox to PAL to play it
