X box component + dolby digital
Discussion in 'Nintendo Forums' started by BigGEORDIE, Sep 12, 2004.
  1. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    Hi there. Big problem. I love picture quality as much as sound quality,is there anywhere I can get a component & digital lead from. everywhere I have looked does one or the other. I have found a svhs+digital lead but no component+digital lead. also if I go component does it have to be progresive scan,the reason is that I use the X1 projector and would rather go interlaced+component+digital. any help would be great.
  2. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    Well, I use the microsoft Hi def kit which has a component out put as well as an optical output.
    I bought high grade optical and component cables from a jap maker "Audio Technica" and use those for my XBox. I get good progressive picture and good DD5.1 sound with all games that support it.
    That Hi def box plugs into the back of the Xbox and has those conection on it that u use.
    I cant hink of any other single cable that ive seen that allows you to use both a component cable and an optical.
    But in the UK there may be some other way. The easyest thing you can do is getting that official XBox High Def kit!
    As for the progresive/ interlace question, well thats an option you can turn on or off in the XBox dashboard picture options. If you cant use Progresive scan just turn it off.
  3. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    The only problem with the hi def pack is that I would have to mod the Xbox, and I dont want to as I have just got it. I have just found a lead from electronic world sold thru Ebay. (XBOX SCART/AV/OPTICAL/S-VIDEO/PHONO/RCA OUT). I know if I dont mod the Xbox I cannot get hi def. but I think with component+optical+coaxial digital out this is the lead for me. Thanks for your help :)
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    BigG
    i got the madcow box too and it's great.
  5. daveb975
    daveb975
    Oct 25, 2002
    4,334
    103
    London
    +370
    I was planning to get the MS Hi Def kit. I was under the impression that it would work on a unmodded PAL Xbox, but you could not access any of the progressive modes.
    I just wanted to use it as a straight component output as that is the only free input I have left on my screen. Will this not work?
  6. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    works fine as componnt interlaced on unmodded box
  7. rubberducker
    rubberducker
    Aug 10, 2004
    345
    this may sound like a stupid question, but do you need to buy componant lead as well as the hi def kit? i was under the impression that it was all in the kit?? please let me know....
  8. BigGEORDIE
    BigGEORDIE
    Jul 30, 2004
    172
    Newcastle
    +4
    hi i need help finding a lead. the lead is XBOX SCART/AV/OPTICAL/S-VIDEO/PHONO/RCA OUT. it was on sale at ebay the other day but now its not .anyone know where i can buy it now
  9. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    BigGEORDIE
    I've moved your other post in here, you have already asked that in this thread. no need to start another thread asking the same thing.
