X Box component cable
Discussion in 'Nintendo Forums' started by Greg Hook, Nov 5, 2004.
  1. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,888
    2
    In a secret location with Jennifer Lawrence
    +9,751
    Trying to find a quality Xbox component cable.
    I want to connect the Xbox to the component connections on my Projector and also connect the sound to my amp.
    Had a quick search on the net but can't find what I want. Found some component cables but they don't have optical for the sound.
    It's a basic Pal unmodded xbox.
    Greg
  2. Koalaboy
    Koalaboy
    Oct 19, 2004
    276
    28
    Plymouth, Devon
    +31
    Lik-Sang supply the official Microsoft cable, albeit of Asian origin, and it's a very nice bit of kit - I received mine just last week.
    I think you'll have to either softmod or chip your box to get a progressive picture though. I did find the component cable gives much better colour.
    HTH,
    Michael.
  3. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    You can't beat the official microsoft hidef pack.
    I got mine from Ebay, but there's a couple of companies in the uk that sell them too, but the names escape me sorry.
  4. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,888
    2
    +9,751
    Will it still work without modding the xbox, albeit just for interlaced?
  5. buzlightyear
    buzlightyear
    Oct 8, 2002
    959
    46
    London
    +119
    Yes, modding will just get you prog scan,
  6. John
    John
    Dec 13, 2002
    11,309
    +2,924
    Try PM'ing LABRAT he always seem to have loads
  7. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,146
    41
    NW London
    +17
    if you change the region to US but dont connect component, should you still get the high def options? A mate wanted to know and I cant be bothered to check :p .....
  8. Only777
    Only777
    Sep 9, 2004
    699
    46
    Cumbria
    +124
    no
  9. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,888
    2
    +9,751
    Sorry for being a dunce, but can someone post a link to one of these MS Component cables. All the ones I have found on liksang and elsewhere don't have the optical cable for the sound.
    Greg
  10. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,146
    41
    NW London
    +17
  11. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,888
    2
    +9,751
    Doh!
    and this will work with my Pal Unmodded Xbox?
    The description says 'except Pal'
  12. Shahel
    Shahel
    you can only run in hidef mode on NTSC xbox or a pal one that is switched to NTSC and im not to sure about this but as far as i can tell if i connect my pal normal xbox to my plasma via component the colour is all funky :(
  13. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,146
    41
    NW London
    +17
    I think it went purple when i had the component on a pal xbox... Not entirely sure though....
    Best is just to do a region switch if you want it for live still...
