X Box cable
Discussion in 'Cables & Switches' started by Mr..Smith, Dec 19, 2004.
  1. Mr..Smith
    Mr..Smith
    Can anyone please tell me where I can buy an official component and audio cable for my xbox so that I can get my xbox to utilise progressive scan on my tv? Ive seen one on tvcables but im not sure if it will work as well as the official. Can anyone help please? :lease:
    Alex
  2. John
    John
    Dec 13, 2002
    11,284
    +2,894
    Lik sang is where I got mine from earlier this year .You should check out the classifieds on here ,as they frequently pop up .Maybe even post a wanted ad.
    A pm to Labrat could help
    If you have not already done so , you will need to mod the box to enable the progressive capabilities (unless its a US one )
    atb
    JS
  3. Mr..Smith
    Mr..Smith
    Its a moded xbox do I just flick it into NTSC? Apparently Halo2 looks amazin with this cable if you have a progressive scan tv
    Alex
  4. John
    John
    Dec 13, 2002
    11,284
    +2,894
    Sorry mate , been at work :D
    Yep , enable the Switcher from PAL to NTSC , you will then need to find your way to the MS dashboard and enable the extra modes in the video section (where you set it to widescreen / pal60) . These modes will only be visable when you plug in the hi def lead (the box knows :D )
    atb
    JS
  5. Mr..Smith
    Mr..Smith
    Excellent, been on lik san and ordered one, :) cant wait. And cant belive im just findin this stuff out now...duh! :oops:
    Now Im thinkin I want all my consoles through component though. Can you get a multi connector for component leads?
    Alex
  6. stazman
    stazman
    Nov 17, 2004
    Darlington
    I was thinking about doing the dashboard software hack to access progressive scan. Does anyone know if it mucks up XBox live?
    (I am doing the Splinter Cell gamesave hack to run the video switcher to set to NTSC. Do I need to remove the video switcher from the hard drive after?)
