x-box as a DVD player
Discussion in 'Plasma TVs Forum' started by tabs, Apr 18, 2005.
  1. tabs
    tabs
    Apr 3, 2005
    1,926
    warks
    +129
    is the x-box DVD playback capabilities up to scratch to go with a plasma ?..just checking really to see if i can save a few quid on a new DVD player thanks
  2. Hitby
    Hitby
    Feb 2, 2005
    4,741
    Middlesbrough
    +544
    Having had the same thought I tried it and even through Component with all hidef modes switched on the xbox WON'T play dvd's in progressive scan, it's noticably worse than my Yamada ProScan DVD recorder which was about a hundred quid. I don't have the dvd remote kit but I shouldn't think that that makes any difference.
    Dan
  3. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    We've been using the PS2 as our DVD player for far too long now... :) The picture is OK on a 28" CRT, but controlling it is a nightmare and the fans are really starting to bug me!
  4. rickyroma
    rickyroma
    Jan 15, 2005
    923
    Dublin
    +70
    if you softmod or chip your xbox you can edit the xbox dvd player to run in progressive scan along with the dashboard , but if you've forked out for a plasma you should go the whole hog and get a nice dvd player to complete the setup (if you can)
  5. swellmel
    swellmel
    hi, noted your comments with regard to modded xbox,my son has one so i connected it to plasma,noticed in menu it says it can play divx movies,how do i edit it to progressive scan mode
