x-box american football?
barrykil
hi
anybody played any american football games? are there any that are any good,that you could reccomend, it could be a xmas prezzie,i know ziltch when it comes to grid iron?
thanks
CarlB
I prefer NFL Fever on te XBox as it has a more 'arcade' slant to it than the Madden series. If you want maximum realism go for Madden, but if you want to pick up and play without loads of backround knowledge I recommend Fever highly.
A
Azrikam
I've heard really good things about NFL2K3. That's gonna be my choice. But, it is a more realistic version that Fever, so it depends on what you're looking for.
G
graham.myers
somebody at work brought a video in of him playing madden. It looked very good and very realistic.
M
murphy86uk
Got NFL 2K3 and Fever and played Madden and in my opinion the best is Sega NFL 2K3 by a long way.
I think it is one of the best games on the xbox, iv played it the most.
Everything about it is quality from the great presentation and commentary to the good graphics with fantastic animations, V lifelike.
Id advise getting NFl 2K3, though it is quite sim orientated and takes a while to get into.
A
Azrikam
Murph, is it out already in the UK, or do you have an import copy?
M
murphy86uk
i got an import copy and it was well worth it
i havnt seen it out in the shops over here so assume its not coming out here
a good place to buy import games from is
www.dvdboxoffice.com
thats where i got mine from, but my xbox is american so there might be a problem for you with region codes?
A
Azrikam
Yeah, I can't even find a UK release date, so it looks like I might have to get a mod chip, or settle for Madden. (bleh)
Podcast: Q Acoustics Q3030i, Humax Aura, Roku Streambar & WandaVision Reviews and more...
