X BOX Advanced Scart
Discussion in 'Nintendo Forums' started by Mr_P, Jun 1, 2002.
  1. Mr_P
    Mr_P
    May 17, 2002
    612
    46
    +139
    I originally had a 3rd party Joytech RGB scart connector for my X box. When playing the dvd widescreen version of Harry Potter, my TV would display it correctly, ie full screen, ie not letterbox.
    I swapped the 3rd party connector for the official microsoft advanced scart connector. Now when I play the Harry Potter dvd, it only plays it in letterbox. It will not fill the screen! I have my tv set up correctly so it must be the scart.
    I would have thought that the microsoft connector would have been wired up correctly. Can anyone confirm that this is the case?
    Also does anyone recommend a better RGB XBox scart connector?
    Thanks.
  2. thestorm
    thestorm
    Jul 13, 2000
    518
    East London, UK
    +8
    did u check of the xbox has got the correct settings like :
    4:3 or 16:9?
    go into xbox "dashboard" and check it out.
    and check what ure tv is set to for : is it auto detect aspect ratios
    or permanenetly full screen?
    hope this helps,
    Shaz
