X Box 360 Live Settings For Netgear Dg834
Discussion in 'Xbox Forums' started by adw2007uk, Jun 6, 2008.
  1. adw2007uk
    adw2007uk
    Jun 6, 2008
    Here's what happened net gear router been unplugged for two weeks before that worked fine with my x box live now it can find my ip address put that in still says ip addresss failed phoned up x box live they said must have wrong wep key looked in router settings found wep key i was correct now what do i do ? should i ring x box live back ?
    please help thanks alan :lease:
  2. chrisbrown1
    chrisbrown1
    Nov 22, 2008
    2
    i hav the same router but i cant get xbox live in the first place, can you help?
    it keeps saying ip address failed and i dont no what to do.
  3. setjellyfish
    setjellyfish
    Nov 20, 2005
    265
    Bedfordshire
    +17
    Turn off all you wireless security and try it again, if it works you know it's a security issue. Check your wireless access list on your router too, your xbox might not be in there, again turn it off and see if you xbox connects. Also make sure wireless is turn on *
    * assuming you using wireless
  4. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,956
    2
    Manchester
    +4,470
