X Box 360 HD DVD Drive firmware updates
Discussion in 'Xbox Forums' started by 1doug1, Sep 11, 2007.
  1. 1doug1
    1doug1
    Apr 6, 2007
    46
    +5
    I bought the HD DVD drive in late August. It's good but I've noticed a couple of issues such as Matrix Reloaded freezing part way through. In addition, the disc menu system for Warner discs that appears at the bottom of the screen causes that part of the picture to disappear, rather annoying.
    I have found out that there is a firmware update from May 2007, the software disc that came with the drive was dated 2006. The new firmware is from the US site, has anyone installed this and if so, does it help? There don't seem to be any updates on the GB site I don't want to cause more problems than I solve. I'll have to burn it to a DVD as I haven't got X Box Live at the moment.
    Many thanks
  2. eternaldark
    eternaldark
    Oct 23, 2004
    1,410
    Inverness
    +62
    Can you not hook up to a m8's connection to download updates?
    I'm upto date with all the firmware updates and Matrix trilogy runs fine
  3. Bald Monkey
    Bald Monkey
    Aug 11, 2006
    7,123
    +1,084
    AFAIK, if you can get the US updates on disc this should be fine, the US and UK machines are identical and there should not be any problems using US updates..
  4. 1doug1
    1doug1
    Apr 6, 2007
    46
    +5
    Cheers Guys, both posts are v helpful. I'll try them out. Once again, thanks
    Doug
  5. miunkimafia
    miunkimafia
    Apr 4, 2007
    20
    Hi guys,
    How do you find out what firmware your HD-DVD is running, and where can you go to get the update?
    Is it only over XBOX Live? Cant find it on the MS website.
  6. Bald Monkey
    Bald Monkey
    Aug 11, 2006
    7,123
    +1,084
  7. miunkimafia
    miunkimafia
    Apr 4, 2007
    20
    Unfortunately the link in the FAQ doesnt work. :mad:
  8. Bald Monkey
    Bald Monkey
    Aug 11, 2006
    7,123
    +1,084
    :eek: :oops: :rotfl: Cheers :D
    I'll try and track down the new link then and PM m1ket and see if we can update it... might not be tonight though...;) I guess I've got lazy with live and auto updates.. ;)
    Try this page for now...
    click on the here in the title haf way down... ;) should download this file... :)
