X-Box 360 connection to Onkyo 505E
Discussion in 'AV Receivers & Amplifiers' started by bournie23, Feb 9, 2009.
Tags:
  1. bournie23
    bournie23
    Jun 28, 2007
    11
    +7
    Hi guys,
    I was wondering of anyone could answer a question I have regarding connecting and X-Box 360 into an Onkyo 505E via the component connection.
    The problem I have is that my LCD screen in now mounted on the wall and the standard X-Box lead is not long enough to reach to directly connect to component leads into the screen. I was wondering if I could connect the standard X-Box lead into my Onkyo 505E, then using a standard 3 Meter Component lead connect from the Amp to my Samsung LCD screen. I also output the sound from the X-Box into the Onkyo via an optical connection would, this still work ok if the video signal was being passed through the amp at the same time.
    Hope someone can help
    James.
    :eek:
  2. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Sounds feasible as long as you can assign the optical to the chosen composite in.
  3. bournie23
    bournie23
    Jun 28, 2007
    11
    +7
    Thanks for that, I would usually just connect the X-Box directly to the screen but the cost of a 3 meter X-Box lead is in the region of £35 - £45, which is considerably more than a standard Component lead the same length.
  4. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Incidentally I am maxed out on HDMI so if I buy a Blu-Ray player my 360 seems the logical candidate for changing to Composite. I am hoping the difference is almost indiscernible.:hiya:
  5. bournie23
    bournie23
    Jun 28, 2007
    11
    +7
    The quality of the X-Box through the composite is great your won't be disappointed if you have to go that way.
  6. ChrisAV
    ChrisAV
    Dec 5, 2008
    766
    43
    Wirral
    +110
    Component?
  7. William YZF-R1
    William YZF-R1
    Nov 5, 2008
    4,255
    +536
    Thank you, you are right of course, I used to notice the same mistake often on the Forum, it must be catching:eek:
  8. ChrisAV
    ChrisAV
    Dec 5, 2008
    766
    43
    Wirral
    +110
    Bound to happen, sonner or later :D
