X-Arcade - Dual Controller and USB
Discussion in 'PC Gaming & Rigs' started by DannyH, Jun 20, 2005.
  1. DannyH
    DannyH
    Just wondering if anyone has managed to get the x-arcade working with a standard USB to PS/2 adapter?
  2. Andy Leitch
    Andy Leitch
    Apr 27, 2005
    548
    None of your business
    +60
    Not sure what you mean by standard USB to PS/2....do you mean one not bought from X-Arcade??
    I bought the orginal USB adapter, which is not the X-Arcade branded product they now show. The one I have is a Y adapter, manufactured by PI Engineering, Williamston, Michigan.....both mouse and keyboard are plugged in at the same time. It works fine...although I do have an early X-Arcade, which has the 'multiple key-press' problem.
    There was an IC swap-out for this...but the original UK distributor has now gone bust, and the current distributor isn't much help. :( :(
