wtd speakers
Discussion in 'Home Cinema Building DIY' started by tightjock, Nov 28, 2004.
  1. tightjock
    tightjock
    hi looking for 5.1 speakers to partner my denon adv1000.or can you recommend something suitable.wife likes celestion avp 302 305 because they match the telly,anyone tried these would value your opinions.cheers
  2. wookie
    wookie
    Hi Jock!
    The AVP Celestions are easily as good as the "new" Genies from MS.
    The sub is adequate for sensible people in "normal" households.
    Use a faily good av receiver like a Yam DSP-AX750 etc and they will sound great.
    I have auditioned these speakers on many occasions when they were £800 for the basic 5.1 sub sat pack.
    Some of the prices right now are silly low this system.
    You may have prompted me to pick up a set & a Silver KEF PSW2500 subwofer to go with it all me thinks :D
  3. tightjock
    tightjock
    hi wookie,thanks for the info, Is the denon be able too drive the celestions by itself or would i need a seperate receiver like the yamaha.trying to keep cost down so close to xmas.regards
