WTD: cheap ICE to replace Citroen AX std
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Triggaaar, Mar 29, 2005.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,127
    +1,169
    I know absoulutely nothing about ICE, so please excuse any stupid questions
    My wife's just got a Citroen AX (Echo :smashin:)
    EDIT - Having found a few threads on in car MP3 players, that's the way I'd like to go, so no need for a CD player:
    So... I've seen the Mstation on ebay, looks ok. Are there many other options (not wanting to spend much, just needs to play MP3s off a hard drive or Flash memmory)?
    I'd also like to put better speakers in for her, if it's easy/not too expensive. Would it be best to put a couple of speakers in the parcel shelf and disconnect those in the doors - or replace the ones in the doors too?
  2. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    Blimey this takes me back.I used to have a good system in a citroen ax.The cheapest way to upgrade is to run a sub and a set of components from a good tri-mode capable amp.The front bottle holders in the doors can be removed and a piece of mdf covered with black cloth or vinyl.Then the mids can sit in the pre cut hole.Put the tweeters up on the mirror adjusters.I had a boxed sub in my ax but you could run one free air on a mdf parcel shelf.
  3. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
