Wtd:Canon 300d Accessories
Discussion in 'Photography Forums' started by p.booth, Jan 21, 2004.
  1. p.booth
    p.booth
    Oct 8, 2002
    4,048
    mbro
    +151
    Anyone got any accessories to go with the Canon 300d.
    e.g. a canon
    battery bg-e1 grip. Filters ,lenses etc????
    Cash waiting.
  2. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    nothing for sale but I bought the battery grip for £70ish here (you're not likely to find a second hand one that cheap):
    http://www.digital-cameras.com/shop/showproduct.asp?id=1505
    I got an extra battery, Neutral Density Filter and Circular Polarising Filter from 7dayshop for about £25
    Lenses are those for the Canon EOS range but be aware that Sigma lenses over a year old are not guaranteed to work with the digital bodies. Ebay is a good source of such piece of kit. Good quality lenses from Canon and Sigma would be what I would look for - you don't need the "best quality" (AKA Really Expensive)since the 300d won't benefit from where the expense has gone, i.e. at the edges of the lens as the sensor is blind the that part anyway.
    Hope that helps
  3. p.booth
    p.booth
    Oct 8, 2002
    4,048
    mbro
    +151
    Thanks Wilbur it helps alot. Also congrats on your great taste in music!!!! :D
