Wtd: 9pin female to 9 pin male serial cable
SASMAN
Im trying to find a 9pin female to 9 pin male serial cable, it has to be over 7 meters long.
Does anyone know where i could get one from.
Tom
MarkE19
I had a search around several web sites that I know and the only one to mention a long m/f serial 9 pin cable was Maplin, but that cable was listed as discontinued.
Try phoning around a few Maplin stores to see if they have got any in stock.
Product code: DD32K
M/F 9p V24 Cbl 10m
Good luck,
Mark.
SASMAN
Thanks for the help Mark.
It seems to be harder to find than i thought. If all else fails i will have to make one.
Thanks again
Tom
Joe Fernand
AVForums Sponsor
SASMAN
Drop me a note and I'll get a you a price for a 10m cable - the 9 Pin D-sub we supply for RS422 is normally M to M and around £40.00.
I'll need to get a price for a M to F.
Joe
SASMAN
Hi Joe
Thanks for the help.
It will fit from the 9pin D on the back of the PC to a 9 pin D on a touch screen.
It should be pin 1 to pin 1 pin 2 to pin 2 ect
Male at one end and female at the other.
I need 7.5m in length if it is to be made or longer if off the shelf.
Tom
SASMAN
any news
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
